DrewE
Jul 01, 2018Explorer III
timmac wrote:
MY 08 Bounder with the Ford 5 speed tow haul sort of sucked in the hills than I installed the 5 Star Tuning and now it shifts like the new Ford 6 speed..
Did you know the Ford 5 speed has 6 gears ?
Technically the 5 speed does have six ratios, but two of them are very very close and it only uses one of the two at any time.
Did you know the "extra" gear added when going from the 4 speed to the 5 sperd is 2nd? 1st is the same ratio on both, snd the top three ratios are also the same. The 6 speed on the other hand has an emtirely different set, with noticeably smaller jumps between them. For cruising, the difference between the 5 snd 6 speed units may as well be a change from a 4 speed to a 6 speed.
38,782 PostsLatest Activity: Sep 10, 2026
