pryoclastic
May 10, 2018Explorer
wolfe10 / mfox20, thanks for the replies.
Regarding what rear suspension the coach has I am going to have to say I don't know the correct term to use to describe it.
Here is a picture showing the suspension when I did a full bearing/seal/brake replacement shortly after I purchased the coach.
There is a fairly good sized bolt through the bottom of the plate of the air bags and I noticed that on one side the bolt extends down and out a couple of inches whereas the other side is flush with the plate.
Does that factor in?
The level adjustment for the coach has an option to operate it in manual mode or automatic. The leaning of the coach can be observed when the air system is in automatic mode and it thinks it has reached its "level" point.
If I forget to put it into manual mode when leveling the coach, I can hear the system dumping air or pumping air depending on the situation which is why I was thinking the ride height was somehow off.
Thanks for the help!
38,776 PostsLatest Activity: May 15, 2026
