jhlady
Sep 11, 2017Explorer
After you unlatch the latches and loosen the hose, lift up slightly, push to the back to release the three tabs on the back and then it should raise up the remaining amount so you can slide out the filter. Take your time and don't force anything so you don't break off the tabs etc.
Hope this helps.
Hope this helps.
