MetalGator's avatar
Mar 04, 2020
F53 brake master cylinder failure
The last couple of trips I have noticed that I had oily water under the front drivers side of my 2018 Miramar motorhome. The only time I didn't see a small puddle was when I didn't use the AC on one trip.
The motorhome is still under warranty (Ford) until June so I took it to a large Ford truck dealership that's nearby. I called today to get a status and the service rep said they were waiting on a part, some type of cylinder. I am assuming he was referring to the brake master cylinder as that is where I suspected the leak was coming from.
I think the condensation from running the AC was washing off some of the fluid that was leaking from the cylinder and that was what I was seeing as the puddle under the drivers side.
I only have a little over 11K miles on the motorhome. Is this type of failure common on the F53 chases? I haven't seen much mention of master cylinder failures on the F53 so I am hoping this is an isolated incident.
Burch
  • Interesting. Normally, the dash A/C condensate drain is on the RIGHT side of the front, brake master cylinder/hydraulic booster on the LEFT.
    Did you look under it to locate the source?
