10forty2
Sep 28, 2017Explorer
I may have missed it, but I didn't see where you said what year model and how many miles are on the rig. When we got ours, I was very nervous about how it handled, especially the body sway. When I got under the rig, I saw that all 4 of the sway bar bushings were completely gone....not just worn, but GONE! I replaced them and it made such a significant improvement, I decided to leave the CHF alone. Since then, I have added air bags and replaced the front leaf springs as I had one that was in a negative arch and causing the rig to lean to one side. The leaf spring replacement made a very significant improvement in handling as did the air bags.
To address your problem, I would suggest making sure that the sway bar bushings are in good shape....if they are original, I would also suggest replacing them with a little stiffer poly bushing to take some slack out of the sway bar setup. Since I don't have a trac bar, I can't address that as an improvement, but many have done it and swear by it to stop the pushing you describe when the wind blows or a truck passes. Me, personally, I experience more push from a small car that I do from a big truck. It's weird, but it's what happens.
Get your alignment checked by a big truck place that knows how to align large vehicles, and set the alignment as recommended above. That will help with the rig's handling going down the road (straight-ahead tracking) and keep you from having to constantly adjust the steering to stay in the lane.
There are several other add-ons that you can purchase and install, but at the end of the day, it's never going to drive like a car. I had to resolve myself to that fact and now that I have adjusted my driving style to match that of the rig, I have a much more enjoyable experience when we travel!
38,778 PostsLatest Activity: Jun 10, 2026
