tommy salmon wrote:
I know this has probably been covered ad nauseam in the past, but I can seem to find any info from the past posts. I have already done the budget stabilizer modification and it helps, but my handling on my 2013 Winnebago Vista is still like rowing a bathtub on the ocean. I am almost always towing a Jeep Wrangler while driving, but I have problems with or without towing. What suspension/steering mods have y'all done on the F53 chassis that helped most, and what did not work? Also, I drive in the mountains a lot, and the engine noise gets really annoying pretty quickly, and my wife and I can't even carry on a conversation. Any solutions for the noise? After 11,000 miles, I'm thinking I have to make a change to this rig, move up to a diesel pusher, or go back to a 5er! Thanks in advance for your reply!
Your going to have to do improvements and than you will be happy, you have one already done, what you need next is Monroe shocks, because they ride softer than the stock shocks, airbags also work good set at proper pressure {50psi in back and 22 psi in front}, and the best way for the noise is sound deadening material with sound proofing material installed over the top, do the doghouse, parts of the fire wall and under the floor under the drivers/passenger seat, I did all this and my ride is softer and at least 50 percent quieter.
The reason DP ride better is because they spend more $$ in that department to make it ride soft, gas chassis cost a whole lot less and they skip in that area, also the motorhome makers add no sound proofing in the doghouse area what so ever, use that $100,000 less that you paid for the gas chassis and do improvements, it should cost under $5000 for the improvements and you can keep the extra $95,000 and have a nice vacation..
