carringb wrote:
I've had my wires break (got pinched) in the base of the shifter. I repaired it with telecom splice connectors (they sell them at Home Depot and most other home improvement stores). It is kinda hard to get in there though.
If you have a scan tool, you can run a test to see if its getting the control signal, or if the light just isn't working. Even then, you'll have to do some investigating. As mentioned above, the light is actually on the shifter. It will illuminate "OFF" next to the O/D lettering.
OK I see where it should light up but it doesn't. I unpluged it and found it's three wires. I checked continuity at the wires to see if the switch ever closes its contacts and it doesn't. There's 12 volts at the plug from the truck. I'd guess it's a bad switch.
Should it light up "off" when the keys on and it's in park?
