McKenziek
May 14, 2013Explorer
tatest wrote:McKenziek wrote:
the claimed GCW is 19000 and the GCVW is 35000. Would it be possible to re-tune or even advisable?
It is almost always possible to retune, although some parts swaps may be required, I don't know the details for the various versions of the PowerStroke. I know a lot about bringing 160-250 HP CTDs up to the 300-350 HP level, and a little about building those for drag racing and tractor pulls.
I don't consider it advisable, the whole point of having different engine ratings for different duty cycles is to meet customer expectations of service and longevity. In the search for more power, where do you stop? More important, how do you plan to use the extra power? To tow a heavier load, or to just cut a couple seconds off your acceleration to freeway speed?
Unless you already have a racing engine with an expected life of a few hours or less, you can always up the ante, especially with supercharging and computerized engine controls. A 600 HP 6.7 Powerstroke is not much of a reach, but it is not going to put out that kind of power for 250,000 miles.
Look at it this way. The last of the piston engines for large aircraft had takeoff ratings of 3000+ horsepower. They could sustain that for something like two minutes to ten minutes before immediate self-destruction. Same engine might be 2200 horsepower maximum sustainable, good for a couple hundred hours. Cruise power might be 1600-1800, 300-500 hours. They needed flight engineers managing the engines and logging times and power settings, to optimize engine life, and determine when to rebuild. What you had was a 2200 HP engine with a 140% power setting for takeoff. The extreme cases were about 180% power.
Modern computer controlled engines have, in the pickup truck versions, the equivalent of takeoff power. The marketing department demands this. But the computer engine management goes only so far as to avoid the immediate self-destruction. Although it may be logging other uses of power, it is not set up to tell you "engine life nn%" or predict " nnnn hours before overhaul."
So what you get in a truck that might need to put out 100% power 100% of time, is an engine limited to 100% power. You don't get the 150% output setting provided as a sales tool for the F-250.
Well said. Thank you
