ol__grouch
Oct 25, 2014Explorer
d0n1 wrote:
Hi I did not have a leak test done.
Leak tests are fairly simple. Mix up some soapy water and dribble in on each joint in the lines. If you see bubbles, there's your leak. You can also smell a leak. This is more problematic as you have to get close to sniff. Make sure you don't light a cigarette. Propane has a smell added to let you know you have a leak.
