carringb
Dec 24, 2017Explorer
Fast dings is typically the ABS fault backup alarm, i.e. it supposed to do that if it loses continuity with the ABS warning lamp. This is so folks don't just pull a bulb instead of fixing their brakes.
Since it's intermittent, could just be a loose connector somewhere. Or even a loose bulb, since the instrument cluster does get handles during the RV build.
It's easy to confirm or rule that out, as a Ford dealer or good brake shop can scan for inactive ABS codes, and "lamp-fault" will save. It has to be an ABS-cabable scanner. A regular OBD2 scanner won't see those.
