prepilot_3ck
Sep 03, 2018Explorer
azdryheat wrote:
Your a/c's seem to be working fine. Your a/c's only cool down about 20 degrees from the outside air temperature. Your RV has zip for insulation (it's only Styrofoam in the walls); you have about as much insulation as a Coleman cooler. I'll bet you don't have dual-pane windows, either. I've got 3 a/c's and the mid to low 80's is about all I get when it's triple digits outside.
You are correct sir. I checked the specs and "foam block" is my insulation type. Yikes. The inside of my cabinets are getting hot. My wife and I were making the joke that the Doritos we took out of the cabinet must have been fresh baked because they were still hot. :)
Brian
