prepilot_3ck
Sep 03, 2018Explorer
Chris Bryant wrote:
Just a note that the "20 degrees below outside" is 100% wrong. As Tinstar correctly stated, you get a 20 degree drop between return and supply air. If that rig is black, likely you need three 15k but units to keep cool in above 100 degree weather.
Bottom line is, reduce heat gain first, check ducting for air leaks, last add capacity.
Cool, that makes sense. It is mostly black, blue and white strips and whatnot but the primary color is black.
Brian
