donn0128
May 17, 2013Explorer II
soloblazer wrote:
hey everyone, i have rented Motorhomes in past, and also owned campers, so late last year we decided to buy our first MH, we bought a 97 Fleetwood Flair 31', we got a heck of a deal so couldnt pass on it. We used it a few times last year locally to see how everything work and what did and didnt work, but i have a few things i need some info on before starting repairs.
1. i have a slight vibration, not in steering wheel, but just in general, the passanger seats vibrates if no one is in it, from about 20mph up. i had all the rear tires balanced. i have not had the front ones done yet, but could be next?Drive shaft vibration caused by a bad carrier bearing would be my first guess. Next would be a bad universal joint.
2. The rv seems noisy on the inside when going down the road, just all around noisy, i have road in other rv of same age and older and they seem like they are alot quieter. is this normal for the flair?Probably common for a 16 year old RV. You will probably have to take it for a drive while you or someone else looks for rattles and such.
3. It seems like this is very common issue i have read tons of forums, but i have a exhaust leak, not sure if its a cracked manifold or bad gasket yet, but will this hurt to leave like this for a little while as it seems expensive to fix at least from the shops i have talked to her in NC.What chassis? What motor? If it is a big block Ford, then yes, it is common. Usual cause is broken manifold bolts. Not an easy or cheap fix.
4. I also have the issue of the temp getting hot when pulling mountains or hard acceleration. i dont think it ever overheated as never heard or saw and boiling or overflow. it runs about 200-210 normal and up from there on hills. i have changed and flush radiator and also added water wetter, also changed thermostat.Remember the motor is in a really tight enclosure. There is going to be a lot of heat IF you are pressing it hard. Back off on the throttle and go up the hills slower helps a lot.
5. The engine AC unit, when i got it i could turn the AC on and it would sometimes squeal like crazy so i wold turn off and turn on and it would start to work fine and blow cold for 5 mins then start to squeal again. i changed the belt and it work for about 5 min trip then it started to squeal and eventually broke belt. When it started to squeal the compressor still was turning, so it was locked up and is not locked up now. but could it be the compressor bad or what? My guess? the AC compressor is locked up. A good AC repair man should be able to fix it for you. Again, it is not going to be cheap.
sorry for all the questions, but thanks in advance for the answers.
38,771 PostsLatest Activity: Apr 20, 2026
