2bzy2c
May 17, 2013Explorer II
soloblazer wrote:
hey everyone, i have rented Motorhomes in past, and also owned campers, so late last year we decided to buy our first MH, we bought a 97 Fleetwood Flair 31', we got a heck of a deal so couldnt pass on it. We used it a few times last year locally to see how everything work and what did and didnt work, but i have a few things i need some info on before starting repairs.
1. i have a slight vibration, not in steering wheel, but just in general, the passanger seats vibrates if no one is in it, from about 20mph up. i had all the rear tires balanced. i have not had the front ones done yet, but could be next?
As was suggested, there may be an issue with the drive line. However, I would have the front tires balanced. Much cheaper and frankly more common than a bad drive line.
2. The rv seems noisy on the inside when going down the road, just all around noisy, i have road in other rv of same age and older and they seem like they are alot quieter. is this normal for the flair?
Probably yes. But you mentioned below about an exhaust leak. That certainly would contribute.
3. It seems like this is very common issue i have read tons of forums, but i have a exhaust leak, not sure if its a cracked manifold or bad gasket yet, but will this hurt to leave like this for a little while as it seems expensive to fix at least from the shops i have talked to her in NC.
It is an expensive fix, but worthwhile in my opinion. The solution is to have headers installed. They are not cast iron, and do not have the cracking or bolt breaking issue as with your original equipment
4. I also have the issue of the temp getting hot when pulling mountains or hard acceleration. i dont think it ever overheated as never heard or saw and boiling or overflow. it runs about 200-210 normal and up from there on hills. i have changed and flush radiator and also added water wetter, also changed thermostat.
What is getting hot? The engine or you?
5. The engine AC unit, when i got it i could turn the AC on and it would sometimes squeal like crazy so i wold turn off and turn on and it would start to work fine and blow cold for 5 mins then start to squeal again. i changed the belt and it work for about 5 min trip then it started to squeal and eventually broke belt. When it started to squeal the compressor still was turning, so it was locked up and is not locked up now. but could it be the compressor bad or what?
Probably the compressor. Junk yard item.
sorry for all the questions, but thanks in advance for the answers.
38,771 PostsLatest Activity: Apr 20, 2026
