soloblazer
May 18, 2013Explorer
Great ideas, i took the Mh to a tire shop and they check the tires and said they look good, they also balanced them, i still need to get the front done.
I will check Lowes for material to insulate the engine.
I did not change the cap out
I am going to change the fan clutch out because it does not seem to be roaring.
I understand its a entry level rv, no insult taken. again its a starter MH.
I am pretty handy with working on cars, and have change ac compressors out on pickups and cars before. so should be straight forward, not sure if compressor broke as again it still turns with a belt it just squiks really bad, and still turns but slow, almost like the compressor is getting ready to lock up. i can turn the ac on and it will make a loud squeking noise but the air gets cold, so i know it working just cant run for more then a few minutes as it will break the belt.
Do the headers that will bolt up to my exhaust, meaning i can change the headers myself? without welding?
thanks again for all the info...
38,771 PostsLatest Activity: Apr 20, 2026
