soloblazer
May 24, 2013Explorer
ok, so i have som updates.
1. i changed out the fan clutch, also made sure radiator was clean.
2. i ordered a new AC Compressor, and so in the mean time i gotten a new belt, and i want to test fit it, to make sure it was the right size, because the first time i changed belt it took like 3 times to get the right size, so i put the new belt on, and figured i would start it up and see what happens, and sure enough it seems to be working just fine now.. go figure.
3. i check the u joints, and bearing and all seem to be good and tigher, so i guess next it getting front tires balanced and seeing if the rear tires are out of round.
4. i also installed new airbags in the front, that was actually a easy job, from what i have read seamed like it was hard, but only about a hr to swap both.
So i need to find the light vibrations now and i should be good, most of teh rest seem to be ok. Still need to find the exhaust leak.
So that is my updates so far, again thanks for everyones advice.
38,771 PostsLatest Activity: Apr 20, 2026
