soloblazer
Jun 05, 2013Explorer
Thanks for the info, i have not checked it with a IR gun, but there is no way really to do that, i cant see the front at all because of the AC cond. and the back is blocked at the bottom.
Going up any grade it rises in heat, until the clutch kicks in and it will go back down.
just put a new thermostat in it and didnt change anything at all.
There are fins in the front grill which push air into the radiator.
The only things in front of the radiator are the ac cond. tranny cooler, and electric fan.
I made the electric fan come on all the time and its new as well.
When sitting at idle it will climb up to 220-230
When you level out after a hill or going down hill it goes to 210.
Fan clutch is new as well
This issue is getting worse over the last 8 months since i have had it.
Yes tires have been switched.
38,777 PostsLatest Activity: May 18, 2026
