Greetings! I have a small class C with a even smaller propane tank. Is there a web site that one can go to find propane dealers that can fill permanent mounted tanks? tia hilcntry
You need to find a supply sources that can fill your PERMANENTLY mounted tank by meter. The weight method is not an option. This capability is usually available at propane vendors however, I have encountered propane vendors that had only the weight method capability. This circumstance has been almost solely at camp grounds. They only had the capacity to fill a removable tank by WEIGHT.
