J_R2
Aug 04, 2014Explorer
tropical36 wrote:We have that also, just to the right of the city inlet.J&R wrote:mccsix wrote:Several times i have forgot to switch from city to pump, while traveling. When on city with no city hooked up. Pump runs fast and no water. Have go out and switch to pump.J&R wrote:
Our's has a city and pump valve in wet bay.
And when you're not getting anything out of the faucets, what setting do you have the valves on?
Not all of them work that way, though and ours is automatic with check valves in the line and the pump can be run at the same time with outside water pressure. It does however have a big ball valve near the water inlet, but that's for filling the tank only. The OP could have some inline valves near the pump as well.
38,780 PostsLatest Activity: Jul 04, 2015
