hotbyte
Aug 22, 2013Explorer
old guy wrote:
another reason I don't own a MH. I own a TT with a truck with a 35 gallon tank and never had this problem you are experiencing.
Not to offend, but that is kind of a odd reasoning...If you are low enough to need 25 gallons (not an unreasonable assumption) and gas is $3.50 (probably low end of avg now), it would take $87.50 to fill up. You'll be cut off at $75. If you stop more often, you are swiping more often. You might as well stop once and swipe multiple times. True, you might be getting a little better fuel mileage than a class A but with a 35 gallon tank, you could actually have less miles per tank than the OP.
38,776 PostsLatest Activity: May 14, 2026
