I finally got around to having the MH weighed. I was not able to get 4-coners weighed but was able to weigh front and real axles. The front weighed 6620 therefore I assume half (3310) would be the wei...
Yes, you are correct. Some people will advise to run a few psi extra if you don't know side to side weight. Personally I run 80# all around and monitor tire temps to see if there is any uneven loading. Generally the passenger side runs a few degrees warmer, but not enough to make me want to run higher air pressure on that side.
