goufgators
May 06, 2015Explorer
Finally...
I finally got around to having the MH weighed. I was not able to get 4-coners weighed but was able to weigh front and real axles. The front weighed 6620 therefore I assume half (3310) would be the wei...
goufgators wrote:
I finally got around to having the MH weighed. I was not able to get 4-coners weighed but was able to weigh front and real axles. The front weighed 6620 therefore I assume half (3310) would be the weight for each front wheel. The rear axle weighed 12220 there for each of the four wheels one-fourth that amount or 3640. Now, the Goodyear Tire Inflation chart for 245/70R/19.5 tires begins with 80 psi for weights of 3640 single and 3415 dual. My weights as stated above are less that the minimum weights shown for 80 psi. Based on this, it seems logical that I could be able to run with 80 psi or, preferable, 85 psi and be well within the Goodyear range. Am I correct?
