I finally got around to having the MH weighed. I was not able to get 4-coners weighed but was able to weigh front and real axles. The front weighed 6620 therefore I assume half (3310) would be the wei...
Keep in mind that your actual individual wheel weights will very likely NOT be half the axle weight. They often vary by several hundred pounds and you need both tires inflated to the pressure required to carry the heaviest wheel weight. That's why the 4 corner weighing is so important. However, if you add the additional pounds that would cover the possible mismatch you will do perfectly well.
