suprz's avatar
suprz
Finally brought her home
Picked up our N2U class C today, wqasnt as scary to drive as i had imagined. The only issue so far was when i got home there was a STRONG smell of propane coming from under the coach and upon inspection, i found that when they filled the propane tank the bleed valve was not tightened and it was coming from there, i finger tightened it, but could still catch some odor so i called the dealer up and the rep told me to come back and they would check it. I pulled in and the mechanic was waiting for me! He tightened the bleed valve and did another leak test and used the soapy water etc... And all is now well. We spent the rest of the afternoon in camp "front yard" and got rid of the old tube style TV ( that thing was Heavy!!!) and replaced it with a 32inch led and another one for the bedroom.
I do have a question, is there a way to shut off the stock ford radio display other than using the master switch to the entire coach? Mine is constantly on unless i shut off the master switch.
1 Reply
  • Should be a switch on the dash. That powers the radio from coach batts. This may be on.
    They have different terms for this switch but mfg.
