rk911
Aug 29, 2016Explorer
rookie_rv wrote:
Rookie Rver :C here! How do I find out how much (maximum) load I can put on (house) generator safely? Is there a technique or process to find out let's say running the air conditioner, two tv's, laptop, interior lights, etc....
(Generac 5500)
determine the maximum wattage of the genny. once you know the wattage it's a simple math problem. AMPS = WATTS/VOLTS. so, if you have a 5500-watt genny then the maximum amp load would be 47.82-amps (assumes 115-volt system). some will argue that 110-volts is nominal, other 120-volts. for your purposes they're distinctions without a difference since the resulting math is essentially the same.
the other poster is correct in that 80% of load is about what you can expect without tripping breakers. some AC appliances will consume additional amps for a few seconds at startup before settling down into "cruise" mode.
