MrDoneIt65
Jul 03, 2011Explorer
Just make sure you download the installation instructions. I would also recommend you use the caulking they provide for the cooling fins on the bottom of the foam insert. They tell you to use the foam provided but once you bolt the new coils to the back of the fridge you can't get the tube for the foam in to fill any spaces. If you put the caulking in the lower area, which is what Norcold originally did, then you will have a better seal. And make sure you use the aluminum tape to seal the unit. Just roll it out to the desired length, loosen one end so you can stick it down and then peel the paper off as you place it over the foam and the back of the fridge. It works really well. In order to get the fridge out of the opening I used a motorcycle jack. Wrapped the steel wheels with tape so it wouldn't hurt my flooring and then pulled the fridge into the center of the kitchen covered the top with an old rug and jacked it up agains the ceiling to hold it secure while I removed the blow Norcold coils and replaced them with the Amish unit. One man, done in about 2 hours.
And check the wiring in the control box. Mine had been switched and the cooling fans didn't work. Also, do not disconnect the cooling fans from the wiring harness. You disconnect the wires at the top of the coils and leave the fans connected in the center of the black wire.
38,780 PostsLatest Activity: Aug 05, 2026
