RayChez
Feb 28, 2012Explorer
It is hard to believe that the coil would blow up because of a sensor attached to the pipe, unless the clamp they installed crimped the pipe causing a weak spot. I have had all the recalls and my 1200 LRIM is still working really good for the last nine years. But if it does fail one of these days I will probably look into installing the Amish coil.
38,780 PostsLatest Activity: Aug 05, 2026
