rvrepairnut
Jul 12, 2012Explorer
00 BUCK wrote:
Hope everyone finds this useful. The Norcold solution wasn't a fix, it was a removal of liability. No matter how many times you have the sensor replaced the fridge will not stop overheating and if you bypass the sensor and your rig catches on fire, it's your fault, not Norcolds.
I expect there will be a class action suit on this sooner than latter
norcold never claimed it was a fix.what it does is shut the fridge off in the rare case it overheats from a low cooling fluid situation
it was never designed nor intended as a repair due to overheating.
38,780 PostsLatest Activity: Aug 05, 2026
