MrDoneIt65
Apr 28, 2013Explorer
I replaced the coils in my Norcold almost 3 years ago. It works great. No recall sensor necessary. And I would check the wiring connection for the cooling fans. I found out mine was wired backwards. Even though they are 12 volt pancake fans they will not work if the black wire and white wire are switched in the control panel on the back of the refrigerator. My original coils, with the recall sensor installed, blew out. Instead of buying a residential refrigerator and going through the problem of fit and finish to install it in the motorhome, I put in the Amish made coils. A whole lot cheaper than rebuilding the cabinet area around the fridge and it still works on propane.
Think about it.
Think about it.
