RamonaJ
Dec 23, 2013Explorer
RayChez wrote:RamonaJ wrote:
I recently purchased a 2007 Ambassador and took it out for first time this past weekend. The Norcold refigerator kept shutting down and blowing the breaker at the park when on AC. It did work fine on LP. Another camper advised me my unit might be included in recall. It was and Norcold advised me the fix had been performed on my unit. Will be returning motor home to dealer for fix but would like some ideas from other ref. owners on permanent fix.
If the cooling unit had sprung a leak, it would not work with either propane or AC. So your problem would not be what the recalls were all about. Sounds to me like you have some electrical problem that is over loading the circuit. It could even be a bad circuit breaker.
