MamaGoose
Aug 16, 2015Explorer
Williamh wrote:
I recently had the recall part on the rear of the ref. of the Norold replaced for the 5th time. I was working when I got it home after the repair. Hopefully it will be working when I go to use it next time. I would like to know if anybody knows where i can get a magnet strong enough to reset the recall part. I would like to have one just in case this last recall part does not work. Thanks in advance for any information. William
We just used a magnet from an oil pan heater. It was just what we happened to have on hand. It's quite a strong magnet, don't know the strength of it, though. It took several tries. We only ever had to reset it twice when we had the RV washed and water got in there. We have since made a cover for the sensor using the bottom of a plastic water jug. We put the cover on the sensor when we're going to wash the RV and then remove it when the washing is done. Rain doesn't seem to be an issue, it's just when a pressure washer is used that water will trip the sensor.
