Ivylog wrote:
Glad you were home and got things under control. A MH fire is one of our concerns since we store it IN our home. Did install a fire sprinkler system in the MH bay…hopefully it never gets hot enough in there for them to go off.
Battle Born only sells LiFePO4 batteries which are not fire prone like the type used in laptops. I recently built 600AH of Lithium’s for $1200…cheaper than AGMs.
You could add a 1200A starter solenoid ($25) as your boost solenoid.
Exactly --- LiFePO4 are very safe, and are a better deal than lead in the long run.
when doing a change over to BattleBorn, remember the Chassis batteries are Lead Acid, and you must separate the 2 systems.
