SidecarFlip
Nov 06, 2017Explorer III
Blutoyz wrote:rjxj wrote:
Post pic. It probably needs more dicor. You did use dicor didnt you? I had a leak around the atenna coax wire. The boot had relaxed enough that it looked ok but was not tight enough on the coax cable and water ran several feet over and into a light fixture and trough a ceiling panel joint and onto dinette.
It was a marine fitting so I used silicone and mounted...obviously I didn't quite do enough...LOL
Silicone is not fine for sealing an RV. In fact, it's no good. Dicor or Sikaflex is.
