Blutoyz
Nov 06, 2017Explorer
SidecarFlip wrote:Blutoyz wrote:rjxj wrote:
Post pic. It probably needs more dicor. You did use dicor didnt you? I had a leak around the atenna coax wire. The boot had relaxed enough that it looked ok but was not tight enough on the coax cable and water ran several feet over and into a light fixture and trough a ceiling panel joint and onto dinette.
It was a marine fitting so I used silicone and mounted...obviously I didn't quite do enough...LOL
Silicone is not fine for sealing an RV. In fact, it's no good. Dicor or Sikaflex is.
:B:B
I will get a tube or two of dicor today to fix my screw up on the roof at least
38,769 PostsLatest Activity: Jun 25, 2013
