Looking online for local vehicles I figured I'd be getting something in the 1994-2000 range. Ontario requires an E-test and Mechanical Fitness Certificate before issuing plates. I always have my mechanic look at the non-safety related items before buying a used vehicle so the "motor" part of the purchase should be ok, at least initially. The "home" part is where I have zero experience. What are the weak points I should be paying special attention to, if any? I've looked at a couple of threads about restoring older units and don't want to do an extensive rebuild. But I am reasonably handy and probably able to do a lot of routine maintenance. I very much appreciate all your input.
