evy
Jul 07, 2015Explorer
coolmom42 wrote:
Suggestion on the fridge... if you are going to get a generator, which will be adequate to charge your batteries, consider going with a 12V fridge like an Engel or ARB, instead of an ammonia absorption type.
If you are going to be mostly in campgrounds you could get an electric site and use an electric space heater.
Eliminating propane usage for heat & fridge would let you run off the small bottles and eliminate the need for a tank and piping.
the fridge you see in the pictures is a Dometic Americana 3way 4cu ft.
You can also see in the pictures that I installed a 7.9gal manchester tank under the van.
I bought a small used 110v heater for when I will be plugged to shore power.
thanks
38,769 PostsLatest Activity: Mar 29, 2026
