DallasSteve
Jan 24, 2018Nomad II
devildog1971 wrote:
Another reason I think it is priced low it has a gas engine, if you want to travel much you will use a lot of gas. Not to say a diesel pusher is thrifty, I have had both that were pretty close in size and weight , without towing anything (car or trailer) the gas unit was at the best 5 miles per gallon I have a older diesel pusher it uses no def (diesel exhaust fluid) and now no E G R I now get 11 miles per gallon. (relatively flat ground not pulling a car and leaving the trailer with the motorcycle in it at home) I have a friend that owns a trucking company and he helped rearrange stuff and reprogram the computer more power uses less fuel
I question the implication that a gasser will get 5 MPG at best. Here is a thread about the V10 gasser and people are talking 8-11 MPG. Your comment sounds like scare tactics from a diesel lover.
RV.NET - V10 Gas Mileage
38,769 PostsLatest Activity: Dec 31, 2014
