Vulcan_Rider
Apr 11, 2015Explorer
Fifty4F100 wrote:
The bypass is in place if you wish to put antifreeze in your entire system. If you don't have or use the bypass you are using at least an extra 6 gallons of antifreeze. Not needed.
Maybe I'm missing something here but while you are pumping the pink stuff IN, if you are careful to NOT open any of the HOT faucets, at least not for very long......would that not prevent much of anything from going into the heater ??
Then drain it after everything else is charged with pink ??
38,769 PostsLatest Activity: Mar 31, 2026
