gb76087 wrote:
I have a 2007 Fleetwood Terra LX 34N motorhome with the 3 valve V10 engine. I am generally towing a Colorado pickup, traveling over western U.S. I do not use the Tow/Haul feature and do not use Cruise Control. I will generally keep the speed around 60 to 62 mph. The motorhome averages 7 to 7.5 mpg. My question is "What improvements, considering my driving habits, should I expect after installing the 5 Star mod and which mod would I get, towing or economy?"
Any particular reason you don't use Tow/haul? Very beneficial when descending hills. Tap the brakes and it will downshift to use the lower gears to assist in maintaining a safe speed without having to use and overheat your brakes. It also locks up the torque converter sooner and keeps it locked longer. Hence, preventing slipping and heat generation.
S
