lzasitko
Sep 22, 2008Explorer
Another thing to possibly keep in mind for the roof is a product available at home depot or most other building supply places is a roll of Ice Dam. It is a rubber membrane that has a sticky side, just peel off the paper and it will adhere to the roofing plywood. It is generally used in colder climates along the bottom of the roof to seal the roof against Ice Dams. In weather where it changes from warm to freezing and back again water on the roof melts and at the roof edge it can build up as it refreezes and it can get under the roofing and soak the plywood or chip board and it rots. By using the Ice Dam stuff under the shingle it can't get to the wood. You can nail through it and it will seal around the nails. Put that on and then what you want for roofing and it will never leak.
Good to see some progress made.
Don't know if you caught RVTV this week but they talked to Chad (Chad's Project Homemade 5th wheel).
38,766 PostsLatest Activity: Jan 10, 2026
