PapPappy
Oct 02, 2008Explorer
Gene in NE wrote:
Spectramac - With over 20,400 views of this topic, you have to know there is a lot of interest in your project. As to the insulation, an insulator once told me not to pack it tightly. Good fit is okay. Dead air space is a better insulator than a solid which can conduct temperature. Thermopane windows are better insulators than thicker panes of glass.
As I understand it, they are talking about the fiberglass insulation, when they suggest it be packed loose. The styrofoam that Malcolm is using can be packed tight...the air is in the foam! Packing it in as tight as you can, should be enough...I don't see a reason to invest in the canned foam for the floor. Maybe around the windows or the drains.
WOW! can't believe it's gotten that many hits! Though I do check it every day!
You've got the dance floor done! Now, you can pitch a tent on it, and go camping!!:B
Keep it going...it's looking great!
38,765 PostsLatest Activity: Jan 07, 2026
