Big_Katuna
Aug 30, 2013Explorer II
deandec wrote:
You probably would prefer to mount the swm for your directv inside the mh although it could be mounted on the roof. The power inserter would need to be inside the coach with access to a 110v outlet.
You would then only need to run one cable to each SWM enabled receiver to get multiple channel recording.
I run two cables from my Mini/Max dome and the portable dish to the inside swm switch but only one cable to each receiver and can record 5 channels at the same time on the H34.
Thats what I described. My SWM splitter and power inserter are inside by my sat box, OTA amp,TV and sound amp. I don't use my roof dome anymore as it is not HD.
I use an outside tripod and SWM3 LNB.
I use single run existing factory cable to run two HD sat boxes and OTA signal at both ends of the RV.
H34 is Genie technology' which I decided against.
38,769 PostsLatest Activity: Mar 28, 2026
