tropical36
Apr 12, 2015Explorer II
Our setup for our JK Wrangler and without a steering lock to be concerned with, consists of the READYBRUTE/ELITE, optional READYSTOP breakaway, Demco base plate and a COOLTECH plug in type wiring harness. The above package contains the READYBRAKE surge brake system as well and I for one, would have no other for simplicity and the best bang for the buck. It's also made of aluminum for less handling weight and rated at 8000lb.
For vehicles that need wiring mods in the way of invasive surgery, I would make up a light bar for the hitch receiver and plug into that for my rear lighting. This is easily done by running a wire cable through the frame to the front and wiring it into your umbilical connector. I've helped with doing this for others and using a hitch haul for mounting the lighting as well. Great addition for hauling extra cargo or your bicycles.
