DSDP_Don
Apr 12, 2015Explorer
When you buy RV related products, you can typically buy Good, Better, Best, with probably the one exception of tow bars and brakes. There are several brands of each and each offers different options. I've yet to find the perfect combination. The best you can do is assemble a system that best fits your needs.
That means, you need to take several things into consideration. Will you do your own install, how big/heavy is the toad. What type of motor home do you have. What is your budget. Probably one of the best deals in both price and simplicity is the NSA ReadyBrake. It will work well the coach you're buying and the size of your towed. I own a DP and I'm towing a 6000 pound truck. I found the SMI Air Force One is the more appropriate system for my needs.
So.....take all the suggestions with a grain of salt and concentrate on ones that are similar to what you'll be doing.
