msmith1199
Aug 14, 2016Explorer II
Bill.Satellite wrote:msmith1199 wrote:
I tried to cut and paste from the owners manual and it won't post from some reason when I do that. According to info I found GM puts either a manual or an electronic transfer case in their new trucks. The manual will have a lever similar to a parking brake lever on the floor and the electronic is a knob left of the steering wheel. Both of them have a Neutral positions. Per the 2015 owners manual, as long as you have one of those two types of transfer cases, you can flat tow it if you follow all their directions.
If there is a percentage sign used anywhere in the info you are trying to copy and paste it will not post.
Thanks for the info. I've had that happen a lot and I figured is must be something like that screwing it up.
