We tow a 2015 Ford Focus Titanium 4 down with the 2.0L engine behind a 32' Class C E450. The transmission functions like an automatic but it is actually a manual transmission that is controlled by electronic clutches. It has a keyless ignition system. To tow I (1) push the ignition button, (2)push the brake peddle and (3) shift the transmission selector to Neutral, the display tells me the transmission is ready, (4) push the ignition button again. The last step is to (5) disconnect the negative battery cable. I put a battery switch on the negative cable to make the disconnect easy.
