mahaney
Apr 17, 2015Explorer
Multi34 wrote:
The converter charger of our 2008 RV is an integral model and a part of the electrical distribution box.
Not really. If you take the cover off, you might find that one side is the AC distribution and the other is DC/converter. Why ask for help then come back kind of snarky when someone ask you for more information? That is why you are here right???
The converters are known to go bad. If you are only getting 13VDC to your batteries, how many amps are you getting? It might not be enough to keep your batteries charged. Also, the flickering and you noticing the charger coming on and off could indicate your charger is going out as in surging to try to charge, then shutting off for some reason.
J
