jaycocamper6230's avatar
Dec 18, 2019
Fleetwood Motorhome Owners ... Help!!!
I have a 2006 37U Fleetwood Bounder with the cat diesel. I have the F73-1042 REV M Battery Control Center. While on shorepower only house batteries charge and while engine is running only auxillary batteries charge. Aux start switch on dash does nothing. It has the 200amp Big Boy Battery Isolator. My question is what controls the Big Boy on this year Fleetwoods? Some mention a "BIRD" box (Bi-directional Isolator relay delay) which I have no idea where to find this or is it controlled by the circuit board in the BCC? I put a new Big Boy on and still the same problems. TIA for any guidance
  • "engine is running only auxiliary batteries charge"
    You need to diagnose and repair this. Both chassis and house banks should be charged by the alternator with the engine running.
  • I believe in 2006 this is how they worked. To charge the chassis batteries while plugged in you need a Trikl-Start which charges the chassis batteries off the house batteries while plugged in.
