dougrainer
Oct 02, 2017Nomad
2008 Rev's came standard with AGM batteries. When it came time to replace them, a previous owner went CHEAP and replaced with lead Acid Batteries. Now, you have LEAD ACID batteries and the Coach battery Charging system(The Inverter), is set up to charge AGM batteries. When you replace AGM's with Lead Acid batteries you MUST change the charge parameters in the Inverter for Lead Acid battery charging. Leaving it on AGM setting will cause Lead Acid battery charging failure and slowly destroy the batteries. Doug
