I have not had that problem but let me tell you a story.
Many moons ago my parents replaced the washer and dryer in our laundry area. We also had what is called a "Suds Saver" which is to say we saved the wash water and used it for 2 loads. Well the drain line from this sink did not line up with the pipe in the floor and it would have been a Rube Goldburg pluming job to make it line up so I went out to the garage and found.. a 1 1/4" flexible Radiator hose.. Yes, the first flexible drain "Tail piece" far as I know.
I should have patented the idea.
a good 10 years later that hose failed and was replaced.. In the interm my parents got a new house built and moved the Laundry, Hose and all, to the new house.
People at the time told me that hose would never last due to the chemicals and hot water.. It's designed to hold 220 degree (give or take a bit) under around 12 PSI of Chemical (Antifreeze) laden water... Naturally it lasted.
